12-26-2022 12:43 PM
Our internet is running slow. Have called Ruckus support for help twice in the past. Some Neighbors have said they reached out to Ruckus and has switch replaced. Please help with connection issues.
12-26-2022 01:27 PM
Hi @Smyers22
There is no need to replace the Switch, If you have confirmed that the Connection in your ISP router works fine and the only affected are the devices connected to the ICX7150 Switch, including the access points,it looks like your Switch (ICX7150 Switch) may be booting from the wrong partition, let me add the guide to fix the issue.
Note: if you have access to the Unleashed Dashboard and the Switch can be seen from there, it may look like the following image, ICX7150-C12-Router instead of ICX7150-C12-Switch, now before starting the steps of the guide, I will advise you to cable the computer directly to the Switch since you will have better connectivity than if you connect via wireless.
Guide#1:
Guide#2:
Yarenis Hernández.
Technical Support Engineer | L2 TAC Wired | Lennar Home Community
12-26-2022 02:39 PM
Can you assist with this via computer remote ?
12-27-2022 05:21 AM
Hi @Smyers22
Effective November’2022, ‘Ruckus Support for Lennar Homes customers will no longer be handled by phone or email. We will be exclusively supporting customers via this community forum support model.
If you need something to be clarify on the process, please let us know
Best Regards
Fernando Vasquez
