06-11-2023 07:43 AM
None of the APs (4) are receiving signal from the switch.
06-11-2023 11:00 AM
I have rebooted the switch and tried to connect via comm port without any luck; amber light stays on.
06-12-2023 08:51 AM
Hi @Silverbullet
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, and Access Points do not have power.
2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the cable connections to the Switch ports)
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
06-14-2023 06:39 AM
Hi Imran:
1. This is not a new install. However, it is a replacement for the original unit which was replaced 10 months ago. I included the SN in a previous message.
2. Unit is set up identically to the last unit and was working fine. Not sure If I had a power failure since everything else is in order but from what I can tell the unit is stuck in boot mode. I am unable to connect to the ruckus via computer to switch. Tried putty and the other app as well.
3. Service from the internet provider is stable. I have Smart Home Monitor which I monitor regularly.
4. There are 4 APs connected.
5. Status lights have not changed. One amber and one green; no other lights are on.
Is there a number I can call someone to discuss?
06-16-2023 07:41 AM
Hi Irman: What type of UPS do you recommend? I’m going to purchase one small enough to fit inside the cabinet.
