Showing results forย
Search instead forย
Did you mean:ย
Switch is not connected.
DavidN
โ€ƒ
Hello!
I had my internet working through access points. I had to turn ruckus switch off to put a 3 way outlet to make sure my router and modem are connected in the closet where it is installed and wires are all inside the plastic unit installed by the builder together with the switch. When I reconnected the power to the modem,  router and switch, everything seems to be working as it previously, except the switch is not connected. How do I reconnect the switch so it actually sends the internet signal to the access points? Please see my setup and screen shots of what I mean when I say everything else is connected but switch is not. Thank you for your time!
โ€ƒ
โ€ƒ
9 REPLIES 9
pinky_ruckus
Valued Contributor III
Hello @DavidN ,
I understand that you are unable to access the putty using the Switch IP address
Could you please use the same IP address to login to the web browser and confirm if you are able to access the Switch dashboard?
You should observe the Switch Dashboard, which should be visible upon accessing the appropriate IP address, as illustrated in the screenshot below.
Please click on Login option and try to access the Switch GUI using the login credentials.
Please let us know if you are able to access the dashboard with the obtained IP address.
pinky_ruckus
Hello @DavidN ,
pinky_ruckus
Hello @DavidN ,
pinky_ruckus
Hello @DavidN ,
pinky_ruckus
Hello @DavidN ,
Thank you.
