03-02-2023 08:13 PM
Hello support team,
I am Lennar home owner with ruckus IXC 7150-c12p and an AP. Few days ago, there was power outage. After that:
- We lost Ruckus SSID wifi.
- PoE Ring doorbell is lost signal (maybe power too).
- AP lights: power light is green + flashing, CTL light is solid green.
What we tried: Unplug + reset modem, router, switch, AP. Nothing changed.
Please help.
03-03-2023 04:45 AM
Hi @HOAILE307
Greetings of the day,
For detailed understanding of the issue please let me know the LED status of the switch.
On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on?
2-Make sure it is plugged into a well-known outlet/power source
03-03-2023 07:34 AM
Thank you for quick respond.
Here's some pics I took this morning (I don't know how to upload pics directly, so I used Google Photos instead).
03-03-2023 07:49 AM
Hi @HOAILE307
Thanks for your reply,
Based on the description and images you have shared, on your ICX-7150-C12P Switch, the SYST and PWR lights are steady green, which means the lights are in a normal state.
Also based on your description it seems that the PoE devices are not working connected to the ICX-7150-C12P Switch.
Since the switch is in the normal state you can take Console access to the switch in order to verify, if the switch is able to transfer the power to PoE devices via 12 ports.
To check this, first, we have to get access to the switch, and there are Two ways to get access to the switch.
ICX7150-C12 Router>
Show version
Show inline power
Show inline power detail
Once you are logged in to the ICX-7150-C12P please follow up the same steps that are on point '2'
03-03-2023 12:02 PM
Im having the same issue I'm using a MacBook Pro. all of my connections show ethernet.
What's the simplest way to gain access back to my ap 2g/5g connection?
I've done the rest & this has been going on for a week.
