Showing results forย
Search instead forย
Did you mean:ย
Switch Stuck in Router Mode
Vfermin72
I already know what the issue is and I need to send the switch in and receive a new one. According to the support specialist I spoke with: โ€œConfirmed Switch listed as router on ISP device table. Unable to Telnet to flash image.
Nothing can be done in order to remotely fix the issue and new hardware needs to be sent.
9 REPLIES 9
Hi @xlearntechnow
Thank you.
Can you provide me the steps in how to make option 1 and option 2 works as switch with the same settings. Disable the router options
Hi @xlearntechnow
Thank you for your response.
I apologize for any misunderstanding regarding your query. Could you please elaborate the issue.
Additionally, I would appreciate your response with the four questions I raised in my initial post in this thread.
Hi @xlearntechnow
I would appreciate your response to the four questions I raised in my initial post in this thread.
Thank you.
Hi @xlearntechnow
Thank you.
