09-30-2025 11:01 AM
I have close to 1GB internet speed when connecting my laptop to the ATT modem directly and doing a speed test. Where as I am getting only 100Mbps speed using the ruckus access points.
I have tried using the self help but was unable to connect to the putty device. When doing a SSH Im getting Network error: Connection timed out. Tried with Telnet and similar error, connection refused. Can someone please help with the same.
09-30-2025 03:49 PM
Hello @srikanthng ,
From the response shared, I understand that you are able to login to the Switch using the web browser.
If you can log into the Switch on the web browser, please check the details highlighted in the screenshot below.
Please share the screenshots if stuck at any step or error (if any) and let me know if you have any queries in this regard.
10-06-2025 07:28 AM
Please find the screenshot.
10-06-2025 07:39 AM
What kind of problems do we encounter? Still for a 1GB internet speed, I am getting only upto 400Mbps
10-06-2025 07:45 AM
Hello @srikanthng ,
We understand that you are still having slower speed issues while accessing through Ruckus devices.
Maximum Speed from RUCKUS ICX-7150-C12P Switch:
Maximum Speed Capacity for RUCKUS R510 Access Points:
However, from the Wi-Fi Access Points, this maximum speed cannot be achieved due to some reasons:
Such as
-Ethernet cable quality used to connect the Access Points from the Switch
- It's also worth noting that many electronic devices and appliances, such as microwaves, baby monitors, security cameras, garage door openers, and phones, operate on the 2.4 GHz frequency, which can contribute to interference that reduces the speed.
- Distance between the Access Points and device through which the Internet is accessed. Etc.,
10-08-2025 09:32 AM
Hello @srikanthng ,
