Setting up Ruckus and at&t gateway together with same SSID
sanjiva_srivast
I have a Lennar home with Ruckus r510 and ICX 7150 C12P. I am using it's SSID for all my wi-fi needs. I have internet through at&t and the gateway is also broadcasting a wi-fi SSID that is different than the Ruckus AP. Can I turn the wi-fi off on my gateway? Is this the correct configuration? I want the at&t gateway to have the same SSID so I can get extended coverage...how do I set it up? Does my at&t gateway need to be the primary wi-fi and Ruckus be the bridge? or vice-versa? Also, when the Amazon guy activated the smart home he did not leave any user name and password to get into the Ruckus admin settings. I can get to the unleashed login page but the default user name super/sp-admin does not work. Please help!!!
25 REPLIES 25
AD
This did not work!  We are currently having the same issue as the author of this post.
sanjiva_srivast
Thank you both! The user and password combination does not work for me. I have contacted the builder and awaiting reply.
sanjiva_srivast
Phew! Finally figured it out.... the user name was admin and password was same as my wifi password!
What do you mean the same as your WiFi password?
sanjiva_srivast
Is there any way to add a. 3rd party wifi router as an extender to the Ruckus R510 AP? I looked everywhere in the settings but could not find any place to do so. Appreciate your quick responses. Also, my at7t is a 1 Gbps connection but I don't see speeds more than 250 mpbs even when I am under the R510 AP. Any suggestions?
