09-07-2023 07:13 PM
After losing power, my ceiling WAPs stopped receiving power from the POE cable.
The internet is still feeding to the WAP units. I tested this by plugging the POE cable directly into my computer and the Internet works great. I have also tested the WAPs by plugging them in directly to a power source and they come back online and work great.
How do I get my switch unit to start pushing power to the WAP units again via the POE cable?
09-12-2023 02:34 PM
Hi @Patty
Apologies for the inconvenience.
The picture you shared is not clear. Could you please once again share a Clear picture of the commands output to assist you further?
09-12-2023 02:35 PM
09-12-2023 02:43 PM
09-12-2023 02:49 PM
Hi @Patty
I truly Apologize for the inconvenience caused.
Please note warranty is not covered for such issues, as this is a software issue that can be fixed with the troubleshooting steps.
Effective November’2022, ‘Ruckus Support for Lennar Homes customers will no longer be handled by phone or email or remote session. We will be exclusively supporting customers via this community forum support model only.
And this forum is on a best-effort support basis.
At this point, we should factory reset the RUCKUS ICX-7150-C12P Switch once again by the below process.
Please note, that there will NOT be any loss of data or configuration. Factory reset will just reset with the default configuration.
Please perform the below commands to factory reset the RUCKUS ICX-7150-C12P Switch. (Also please refer to the below screenshot)
erase system factory-default
y
Once the factory reset is complete, the RUCKUS ICX-7150-C12P Switch will discover the Access Points connected to it and it gets connected to the Unlashed system.
Please make sure the management approval is enabled (as described in the below link).
09-12-2023 03:00 PM
d
