08-11-2023 08:38 AM
My rukus routers are not powering up the one in 1st floor and 2nd floor. How to turn them on? As I don't see any power switch
08-11-2023 12:38 PM
Hi @Raghukm
Thank you for the PICTURES you shared.
As we can see from the pictures you shared there are lights on PWR and SYST, if there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
First, we will try to reset the Switch as described below:
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
08-11-2023 12:58 PM
Where can I find the reset button?
08-11-2023 01:19 PM
Hi @Raghukm
Please refer to the Video I have shared in my previous post, which explains the reset process.
08-11-2023 02:46 PM
I tried to follow step 1 as you posted. It did not make any difference.
I really did not understand what step 2 is doing. Can you or someone please schedule a virtual fix?? I am not a network guy to understand the steps in the video or the documentation
Kindly help me out
08-11-2023 02:58 PM
Hi @Raghukm
If reset does not make any difference we have to go with software recovery to the Switch.
Apologies, Effective November’2022, ‘Ruckus Support for Lennar Homes customers will no longer be handled by phone or email or remote session. We will be exclusively supporting customers via this community forum support model only.
RUCKUS does not have any support team of technicians to support on-site for Lennar Homes.
We have tried to create the guides as non-technical as possible, so that they are not much difficult to follow. I request you follow the software recovery guide step-by-step and if you get stuck at any point please let us know we will assist you proceed further.
Please do let us know if there is any help required on the troubleshooting steps or if you are stuck at any point. We are happy to help you.
