Rukus box is going in and out every few mins
Lazarus
My rukus box is keep going in and out after every few mins. Its causing disturbance on Ethernet and wifi both.
30 REPLIES 30
Lazarus
After pasting IP in browser it ask for login and password and i don't know what to go after that .
Hello @Lazarus ,
I understand that you have accessed the IP address of the Switch and unable to login to the CLI.
Once we identify the IP address of the Switch proceed to access the RUCKUS ICX-7150-C12P Switch using a Web Browser.
Please click on Login option and try to access the Switch GUI using the login credentials.
Switch default credentials will be as mentioned below.
Username: super
Password: sp-admin
If the above credentials don’t work, you can try the default credential combinations below as well.
These usernames and passwords are key sensitive, please use capital letters where necessary.
Lazarus
I got following response but i am unable to use this login info with instructions,
Username: super
Password: sp-admin
Hello @Lazarus ,
From the response you shared, I see that the IP address you used is for the AP and not of the Switch.
I recommend cross-checking the IP addresses listed in the IP scan results under the names "Ruckus Wireless" or "Brocade Communications" to
Username: super
Password: sp-admin
you are keep making it more confusing. Is there any way you can call me?
