02-01-2024 02:57 PM
I flipped all the switches on my electricity breakers box to fix some other issue, but my wi-fi stopped working since then. No lights are blinking on the WAP box. Please help.
Thanks,
Viji
02-05-2024 06:08 PM
I followed the steps. Nothing is shown in putty. It just opened a black screen with a small green rectangle. Please see the following screen shots.
Please advice.
Thanks!
02-07-2024 05:55 AM
Hi @vijaya173
To access by console you must install a driver so that the workstation/pc/desktop or laptop can recognize the cable
Make sure to download the zip drive for the file below & "extract all". Once it's extracted, run the file ,driver should be installed.
Link:https://support.ruckuswireless.com/software/1414-brocade-ruckus-7150-usb-serial-driver-windows
Please install the drivers, and then attempt to access again.
Feel free to contact me if you have questions.
Kind regards,
Sofia Gätjens
02-07-2024 11:38 AM
I already extracted and installed these drivers as shown in the link. When I connect the cable I see the port in Device Manager and I also see the device icon "Silicon Labs CP210x USB to UART Bridge (COM3)" under devices and printers. Please see both the screen shots I attached above. Nothing is shown in putty. It just opened a black screen with a small green rectangle. Please advice.
Thanks!
02-08-2024 06:22 AM
Hi @vijaya173
If after attempting this, you still cannot access the ICX and nothing is displayed in PuTTY, please try using another cable. The cable should be Type-C to Type A (standard USB).
Please provide a picture of the ICX connected to the PC with the USB cable, showing the system lights on the switch.
Kind regards,
Sofia Gätjens
02-09-2024 12:35 PM
I tried with a different cable, which is also Type-C to Type A. I also tried with different computer. I tried with both Putty and MobaXterm on both the computers with different cables of Type-C to Type A. I already extracted and installed these drivers as shown in the link. When I connect the cable I see the port in Device Manager and I also see the device icon "Silicon Labs CP210x USB to UART Bridge (COM5)" under devices and printers. Please see the screen shots I attached here. Nothing is shown in putty. It just opened a black screen with a small green rectangle. MobaXterm is showing "Error 5: Access denied" with one cable and showing a blank screen with different cable of the same type. Please advice.
