Ruckus system randomly cycling
ajc
My home has  ICX7150-C12-Switch and 2 r510 ap.  The Ruckus system seems to reset randomly.  The ATT fiber router/modem is not as internet is available through ATT.  The switch does not show up in the Unleashed app but the access points do.  I connected my laptop directly to the switch but cannot get pass the login (192.168.1.100) using any of the passwords I originally got from the tech ( super &sp-admin, admin & ruckus). Called Ruckus and they say i must post to forum.  Any assistance would be appreciated.  Home built in 2019.
33 REPLIES 33
ajc
I have not tried the password recovery in MobaXterm as yet.  I will try that this afternoon.
Hi @ajc
Thanks for your update.
Please let us know the result once you are done with the above process.
ajc
So i logged in using the Mobaxterm.  This is what I got.  I connected again for over 40 minute and it will not come out of this mode.
Hi @ajc
For detailed understanding of the issue please share the output of the following commands by gaining access to the switch using the below guide.
show lldp neighbors
show poe
show version
show flash
show log
Also please share the screenshot of the status of the switch and the access points as mentioned below.
 Admin & Services > Administer > Upgrade
ajc
telnet@ICX7150-C12 Switch>show lldp neighbors
LLDP is not running
telnet@ICX7150-C12 Switch>show poe
Power Capacity:         Total is 124000 mWatts. Current Free is 93200 mWatts.
Power Allocations:      Requests Honored 17 times
 Port   Admin   Oper    ---Power(mWatts)---  PD Type  PD Class     Pri  Fault/
        State   State   Consumed  Allocated                             Error
  1/1/1 On      On          3200      15400  2P-IEEE  Class 3        3  n/a
  1/1/2 On      Off            0          0  n/a      n/a            3  n/a
  1/1/3 On      On          3000      15400  2P-IEEE  Class 3        3  n/a
  1/1/4 On      Off            0          0  n/a      n/a            3  n/a
  1/1/5 On      Off            0          0  n/a      n/a            3  n/a
  1/1/6 On      Off            0          0  n/a      n/a            3  n/a
  1/1/7 On      Off            0          0  n/a      n/a            3  n/a
  1/1/8 On      Non-PD         0          0  n/a      n/a            3  n/a
  1/1/9 On      Non-PD         0          0  n/a      n/a            3  n/a
 1/1/10 On      Non-PD         0          0  n/a      n/a            3  n/a
 1/1/11 On      Non-PD         0          0  n/a      n/a            3  n/a
 1/1/12 On      Non-PD         0          0  n/a      n/a            3  n/a
 Total                      6200      30800
telnet@ICX7150-C12 Switch>show version
    UNIT 1: compiled on Jun  9 2023 at 06:14:36 labeled as SPS08095k
      (31457280 bytes) from Primary SPS08095k.bin (UFI)
        SW: Version 08.0.95kT211
      Compressed Secondary Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
       Compiled on Tue Nov 29 12:43:26 2022
  HW: Stackable ICX7150-C12-POE
      Serial  #:FEK3817Q1TY
      Current License: 2X1G
      P-ASIC  0: type B160, rev 11  Chip BCM56160_B0
    8 MB boot flash memory
    2 GB code flash memory
    1 GB DRAM
STACKID 1  system uptime is 3 day(s) 9 hour(s) 9 minute(s) 13 second(s)
The system started at 06:14:38 GMT+00 Fri Jun 09 2023
telnet@ICX7150-C12 Switch>show flash
Stack unit 1:
  Compressed Pri Code size = 31457280, Version:08.0.95kT211 (SPS08095k.bin)
  Compressed Sec Code size = 31457280, Version:08.0.95kT211 (SPS08095k.bin)
  Compressed Pri Boot Code size = 786944, Version:10.1.14T225 (mnz10114)
  Compressed Sec Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
  Code Flash Free Space = 1099386880
