07-25-2023 07:56 PM
My home has ICX7150-C12-Switch and 2 r510 ap. The Ruckus system seems to reset randomly. The ATT fiber router/modem is not as internet is available through ATT. The switch does not show up in the Unleashed app but the access points do. I connected my laptop directly to the switch but cannot get pass the login (192.168.1.100) using any of the passwords I originally got from the tech ( super &sp-admin, admin & ruckus). Called Ruckus and they say i must post to forum. Any assistance would be appreciated. Home built in 2019.
07-26-2023 06:09 AM
Hi @ajc
Greetings of the day,
If the default credentials doesn't work please try the most common username and passwords ( This is key sensitive so please include capital letters )
Username:admin password: Ruckus!
Username:admin password: Ruckus1
Username:admin password: Lennar
Username:super password: sp-admin
Admin usernames and passwords for the Ruckus Wi-Fi Access Points/Switch for Lennar home users
Also for detailed understanding of the issue please let us know the LED status of the switch and the access points using the below guide.
R510 LED lights
RUCKUS LED lights
07-31-2023 05:31 AM
Hi @ajc
Thanks for your response.
Please let us know the LED status of the switch using the below guide. Also please share the image of the switch showing the LED status and the cable connections.
RUCKUS LED lights
To perform password recovery please use the MobaXterm app (similar to putty) and follow the password recovery steps.
For MacOS system like like MacBook we can access from the terminal of the device without having to install a tool.
For Telnet access:
nc ‘IP of the device’ 23
For ssh Access:
ssh ‘username’@’IP of the device’
Note: if access to ssh does not work tried the following ssh-keygen -R 'ip address of the device' this generates a public key pair for use when authenticating with a remote server.
07-31-2023 10:32 AM
Figure 1. Port-side LEDs of ICX 7150-C12P
cables with white paint are aps, dark blue cable is att gateway, other eth cables are devices (camera, doorlock, etc)
master ap
att gateway
07-31-2023 11:06 AM
Hi @ajc
Please let us know whether you have tried the password recovery process in MobaXterm app. If not please try the password recovery process and let us know the result.
