12-06-2022 05:50 AM
i have a lennar home, a ruckus switch, 2 APs, and for a week now, we have not been able to get a connection through the switch. lights are on on the APs, the network shows up but once connected, you're offline. it makes no sense. i have no idea what to do, ruckus will not help me, and i need my internet in order to get my job done. as another user said, the "instructions" provided here are way over my head, i think it's ridiculous that it's taking me this long to get the issue resolved, and i still see no end in sight. can anyone help me?
12-07-2022 04:15 PM - edited 12-07-2022 04:18 PM
Hi @relingburg
Please run the next commands to fix the routing code issue, when the switch comes back, or you have time you can upgrade to the code 08095g, however, after running the commands that I will provide the slow connectivity will be fixed.
Commands:
copy flash flash secondary
write memory
Boot system flash primary yes
Example and explanation:
ICX7150-C12 Router>enable
ICX7150-C12 Router>show flash (you can confirm in which partition you have the correct code that will start with SPS example: SPS08080f.bin normally will be your primary partition)
ICX7150-C12 Router#copy flash flash secondary (this will copy what is in your primary code to the secondary)
ICX7150-C12 Router# write memory
ICX7150-C12 Router#show flash (now both partitions must start with the SPS before the code type)
ICX7150-C12 Router#Boot system flash primary yes
Yarenis Hernández
03-09-2023 02:38 PM
Hi @relingburg
Thank you for the response and update.
Great!!!
Now your Switch has been upgraded to the latest stable Version SPS 8095g on both Primary and Secondary partitions.
Have a great day ahead!!!
Thank you again for contacting RUCKUS Lennar Home Community.
03-09-2023 02:43 PM
why is my switch still red on the app?
03-09-2023 03:55 PM
Hi @relingburg
It will take some time to get the Switch synchronize with the Access Points/Unleashed. Kindly check after some time.
Thank you again.
03-10-2023 03:58 AM
it’s been 12 hours… it still says connecting on the app, and is labeled as “router.” how long does it take to sync?
03-10-2023 07:24 AM
Hi @relingburg
As your Switch is showing as pending/connecting it could be for multiple reasons, (Please refer to the below picture)
Please follow the below steps to get Switch in sync with Unleashed. We will delete the Switch from Unleased and Add it back.
Steps to synchronize the Switch (ICX-7150-C12P) to the unleashed Access Points:
Switch side:
Make sure the management approval is enabled.
Access Points (unleashed) :
On the Unleashed dashboard
1- Remove the existing Switch from the Unleashed (Please refer to the below picture):
2-Hit Add on that dashboard
3-Put the IP address of the ICX switch (ICX-7150-C12P) and Password– If you don’t know the IP Address of the Switch. Please perform the below command from the Switch CLI to get the same.
Device>enable
Device#show ip address
4-Username and password for Switch authentication are the same as what you use to log in for Switch on Web or CLI (Putty).
To sync the data, it will take us a while, so after a couple of minutes, it should say connected.
Once the Switch gets synchronized, please check the dashboard again.
Thank you again.
