11-09-2023 11:24 AM
A few days ago my internet started going out. My modem was tested and working fine. Then they brought out a new modem, also worked fine unless I plugged in the Ruckus system.
This system has worked fine for nearly two years. The cords were not disconnected or moved into new locations under the old working monitor.
Xfinity was here and stated the issue is not with the internet but rather the Ruckus system. How can I get help?
11-09-2023 11:56 AM
Hi @ShelleyBerry
As per the case description, I understand that the Internet connection via RUCKUS devices is not working.
1. If it worked before, was there any power outage before you started facing this issue?
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
Please let me know the answers to ALL the above queries or let me know if you have any queries in this regard.
11-09-2023 12:48 PM
11-09-2023 01:36 PM
Hi @ShelleyBerry
As per the light status of the RUCKUS ICX-7150-C12P Switch, it seems to be in a normal status.
As I see from the picture you shared, seems like the ethernet cable which is coming from the ISP’s (Internet Service Provider’s) Router or Modem/Router combo or any other device is plugged into the wrong port on the Switch panel. It must be plugged into any 1 in-12 ports as shown in the below screenshot. Please unplug the ethernet cable and plug it into the correct port and try to connect to the Internet via Access Points. If required please reboot (unplug and plug from the power outlet) your RUCKUS ICX-7150-C12P Switch.
Also, please unplug and plug the ethernet cable from the Switch port, you can plug in any 1 in-12 ports highlighted in the above screenshot.
11-09-2023 03:20 PM
This did not work. My ruckus system is not operating with my internet
