05-24-2024 01:52 AM
My Ruckus switch ICX 7150-C12P stopped working. The switch is powered but no led is ON. When I power ON the module, I see all the leds blink amber for a second and then all leds go back to off. I tried to reset to factory default multiple times (using the reset pin hole), and I still have the same result. I also tried to communicate with the switch via Putty/serial connection and the device is not communicating. Any idea how to fix it?
05-24-2024 07:51 AM
Hi @JPR
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, it flashes amber lights for a second and then goes dark. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
05-24-2024 07:56 AM
05-24-2024 10:10 AM
Hi @JPR
Thank you for reaching out and for your patience as we address your inquiry.
We are always committed to assisting you to the best of our abilities.
Your time and patience regarding this matter are greatly appreciated.
Should you have any further questions or concerns, please don't hesitate to contact us.
We value your continued interest in RUCKUS Lennar Home Community and look forward to assisting you in the future.
Wishing you a pleasant weekend ahead.
