02-07-2024 01:09 PM
ICX 7150-C12P SN FEK3838ROVZ
I lost power and after power was restored the WIFI signal comes and goes, mostly gone..... When there is signal, it is strong.
I've tried rebooting multiple times without an improved consistency. Based on some of the research in the knowledge base, I've include the version and flash output.
Thank you in advance for your help!
ICX7150-C12-Router>enable
ICX7150-C12-Router#show TFTP session timed out
version
UNIT 1: compiled on Sep 23 2019 at 00:00:25 labeled as SPR08090d
(32539748 bytes) from Secondary SPR08090d.bin (Non-UFI)
SW: Version 08.0.90dT213
Compressed Secondary Boot Code size = 786944, Version:10.1.15T225 (mnz10115)
Compiled on Thu Jan 31 07:08:55 2019
HW: Stackable ICX7150-C12-POE
Serial #:FEK3838R0VZ
Software Package: ICX7150_BASE_L3_SOFT_PACKAGE
Current License: 2X1G
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 1 minute(s) 25 second(s)
The system started at 00:03:44 GMT+00 Sat Jan 01 2000
=============== WARNING: FI image is not booted from UFI!!! ===============
====== Please download UFI image and reboot the system for full functionality ======
ICX7150-C12-Router#show flash
Stack unit 1:
Compressed Pri Code size = 28660224, Version:08.0.90dT211 (SPS08090d.bin)
Compressed Sec Code size = 32539748, Version:08.0.90dT213 (SPR08090d.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.15T225 (mnz10115)
Compressed Sec Boot Code size = 786944, Version:10.1.15T225 (mnz10115)
Code Flash Free Space = 1260408832
ICX7150-C12-Router#TFTP session timed out
02-23-2024 12:28 PM
Hi @jeff_schultz
Could you please perform the upgrade of the Switch once again?
Please refer to the below guide for the same.
Please note, start from the below command and IGNORE bootrom and 8080f files and commands.
ICX7150-C12 Router#copy tftp flash 192.168.0.245 SPS0805gufi.bin primary
Apologies for the inconvenience.
Please let me know if you need any help during the process.
02-22-2024 06:27 PM
Hi Imran,
The following is displayed when I use the 192.168.0.105 URL
When I login as admin, following is what is displayed.
Please let me know what additional information I can provide or commands to execute.
THANK YOU!
02-22-2024 06:42 PM
Current show flash and version output via the USB to USB type C console connection.
Stack unit 1:
Code Flash Free Space = 1260380160
ICX7150-C12-Router#show version
Compressed Secondary Boot Code size = 786944, Version:10.1.15T225 (mnz1011 5)
1024 MB DRAM
STACKID 1 system uptime is 11 hour(s) 5 minute(s) 8 second(s)
The system started at 00:05:39 GMT+00 Sat Jan 01 2000
=============== WARNING: FI image is not booted from UFI!!! ========= ======
ICX7150-C12-Router#
Thank you again for your help!
02-23-2024 06:21 AM
Hi @jeff_schultz
This issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
As I can see from the output you shared, your Switch is booted up on the secondary partition which is running on Routing code (SPR) as highlighted in the below screenshot.
copy flash flash secondary
Example:
We suggest upgrading your switch to the latest stable version to avoid this issue in the future. Your Switch is on an older non-UFI version that is 08090d. Once you complete the above process, please perform the Switch upgrade by referring to below RUCKUS Lennar Knowledge base self-help guide below to avoid any issues in the future.
02-23-2024 06:35 AM
Happy Friday Imran,
Thank you for the quick response.
Following is the output of the first command "copy flash flash secondary" where I encounter an error.
Please Enter Login Name: admin
Please Enter Password:
User login successful.
ICX7150-C12-Router#copy flash flash secondaryError in opening /fast_iron/.images /primary.ufi
fopen: No such file or directory
Unable to find a UFI image copy from. Please reload master with appropriate UFI image to proceed with flash-flash copy
ICX7150-C12-Router#
Question: what would happen if I changed the boot sequence to secondary in the following screen shot? Would that boot up in switch mode?
Thanks in advance for your help!
02-23-2024 06:36 AM
Forgot to add the screenshot.
