10-19-2023 10:07 AM - edited 10-19-2023 10:12 AM
Every couple days the RUCKUS device loses power, but if I unplug and plug back in, lights return and everything is on/back to normal. It happened this morning when I woke up and just happened for the first time during the day while using the internet, so it is becoming more frequent.
Started maybe a week or two ago, possibly after a power outage.
canned response question answers:
1.
2. ISP is running, no issues there.
3. Lennar home came with two access points, they all work when I unplug and plug back in the switch, unrelated.
10-19-2023 10:55 AM
Hi @kdaytime
Hope you are doing well!!!
As per the case description, I understand that your RUCKUS devices disconnect randomly after power outages.
This issue may happen when your RUCKUS ICX-7150-C12P Switch is running on an older version. To check and assist you with the same please follow the below process and help me with the queries.
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
Please perform the above process and share the output of the above commands or share the screenshots if stuck at any step or error (if any). Let me know if you have any queries in this regard.
10-19-2023 11:40 AM
I found the IP by connecting to my ISP Gateway.
192.168.1.103 / ICX7150-C12-Switch
But I can't connect to it using PuTTY or MobaXterm
all username/password combinations do not work
10-19-2023 12:05 PM
Hi @kdaytime
Could you please try to log into the Putty using the Telnet option as described below?
Telnet – Port 23
ICX7150-C12 Switch>
show version
show flash
10-19-2023 12:21 PM
telnet@ICX7150-C12 Switch#show version
Copyright (c) 1996-2017 Brocade Communications Systems, Inc. All rights reserved.
UNIT 1: compiled on Aug 14 2017 at 06:54:44 labeled as SPS08061a
(24723488 bytes) from Primary
SW: Version 08.0.61aT211
Compressed Boot-Monitor Image size = 786944, Version:10.1.10T225 (mnz10110)
Compiled on Sun Jun 25 09:25:15 2017
HW: Stackable ICX7150-C12-POE
Serial #:FEK3250N0GM
Current License:
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 2 hour(s) 27 minute(s) 17 second(s)
The system started at 00:02:07 GMT+00 Sat Jan 01 2000
telnet@ICX7150-C12 Switch#show flash
Stack unit 1:
Compressed Pri Code size = 24723488, Version:08.0.61aT211
Compressed Sec Code size = 28314668, Version:08.0.61aT213
Code Flash Free Space = 1312030720
