Ruckus icx 7150-c12p (Lennar Homes) Stopped Sending Power after Power Outage
Mauri21
In early February, I experienced a power outage in the neighborhood.  After the power outage, my ICX 7150 unit stopped supplying my home devices with power.  I did multiple resets on the unit, but the problem remains.  No power comes out of the unit.
This is what I see in the unit:
  • Power and System lights are GREEN
  • Amber lights in Ports 8, 10, 12
  • No lights in Ports 1 and 2 where I have 3 cables that are supposed to supply power to devices like my Ring
Does my unit need to get replaced or reconfigured?  What is the process for that?
PLease let me know
Thanks!
5 REPLIES 5
Valued Contributor III
Hi @Mauri21
Greeting of the day,
As you have mentioned, the ICX-7150-C12P Switch, the SYST and PWR lights are steady green, which means the lights are in a normal state.
Since the switch is in the normal state you can take Console access to the switch in order to verify, if the switch is able to transfer the power to PoE devices via 12 ports.
For better understanding of the issue, we have to get access to the switch, and there are Two ways to get access to the switch.
  1. I) By IP Address of the Switch OR
  2. II) By Console Access to the Switch
  1. By IP address: To fix this issue, we must identify the ‘current’ IP address assigned by your local router to the switch ICX-7150-C12P
ICX7150-C12 Router>
  1. Now please perform the following commands and share the output:
Show version
Show inline power
Show inline power detail
  1. By Console access: If access via IP address is not possible here is a guide on how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case we need a USB type C to USB standard or Console cable Rj45 to USB.
Once you are logged in to the ICX-7150-C12P please follow up the same steps that are on point '2'
I appreciate the detailed response, but I'm not a technical person.  I don't believe I'm capable of doing what you recommend in your response.  Can you send a technician?  Is there technical support?
It's a bit fustrating because I can't do the stuff you suggest.  Please send me the contact information of technical service that can debug and resolve this issue
Thanks!
Hi @Mauri21
Effective November’2022, ‘Ruckus Support for Lennar Homes customers will no longer be handled by phone or email.
We will be exclusively supporting customers via this community forum support model.
We have tried to create the guides as non-technical as possible, so that they are not difficult to follow; however, if you continue to have difficulty following the steps,
I would recommend that you seek outside help or a technician.
Please try to follow the guides and let us know if you have any issues.
Also please share the screenshot of the error you are facing while trying to solve the issue.
Where do I find a technician?  Please explain
Thanks!
