Ruckus box needs to be replaced after lightning strike
mikib973
After a lightning strike across the street, my ruckus box stopped working. It’s been reset multiple times and nothing. This has happened before, 3 years ago, and the box needed to be replaced.  I called and was told to post this here and I should get a response from a tech.
thx
ruckus  ICX 7150-C12P
SN: *****
1 ACCEPTED SOLUTION
Imran_ruckus
Hi @mikib973
I recommend again attempting a physical factory reset multiple times, as outlined in our RUCKUS Lennar Knowledge Base self-help article accessible through this link and VIDEO:
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/Process-for-performing-a-phy...
Video link: https://www.youtube.com/watch?v=6jHMTdo_hK4
If the initial reset attempts do not resolve the issue, please try resetting your switch multiple times (approximately 10-15 times) using the method described in the article. In some cases, repeated attempts have successfully resolved similar issues. Upon successful reset, the SYST and PWR lights should turn GREEN.
If hard reset doesn't work, please proceed with the below process:
21 REPLIES 21
Hi @mikib973
Thank you for your response.
I apologize for any inconvenience, but as this appears to be a software issue, we need to follow our troubleshooting procedures as per our policy before considering a replacement.
Could you please confirm if you have performed a software recovery on the Switch? If yes, please let me know at what step you are stuck.
Hi @mikib973
