10-07-2025 06:24 PM
After a power outage I noticed that my wifi keeps dropping and has been very inconsistent. This same issue happened to me about 2 years ago and I resolved the issue by running the CLI and ensuring the Switch was running with the SPS code instead of the SPR code. Now, however, after running the CLI, I can confirm that the Switch is still running with the SPS code so I am not sure what the issue is. I have checked other threads and I don't see the same issue. Also, not sure if it matters but in the Ruckus app, I do not see a Switch listed in the main screen carousel - could this be causing an issue?
I understand I am still under warranty - please let me know if this is something that warrants a replacement given this background. Product is ICX7150-C12P-2X1G.
Thank you!
10-22-2025 08:21 AM
Thank you.
10-24-2025 05:13 AM
Thank you.
10-28-2025 05:06 AM
Thank you.
10-10-2025 09:28 AM - edited 10-10-2025 09:33 AM
The WAPs finally came back after around 30 minutes, however, the tool never said that the upgrade was complete and now the tool is not detecting any device version. Also important to point out that the admin password that I reset no longer works - what should be done? Re-do the reset?
Please let me know what the next steps would be to verify that the Switch is working properly now with the correct UFI.
