09-17-2025 11:43 AM - edited 09-17-2025 12:54 PM
09-17-2025 12:53 PM
Hi @Auggie
Based on the information provided, it appears that one of your RUCKUS Access Points is not powering ON.
Please note, these Access Points (APs) receive power through Power over Ethernet (PoE) function. That is it receives power through the Switch Ports. There is no battery involved.
When your switch is connected to the outlet, do you observe any illuminated lights (amber or green)? Kindly describe which lights are visible. Additionally, please provide a photo showing the status of the lights and the full switch panel with cable connections to the switch ports.
09-17-2025 12:33 PM
Hi @Auggie
Could you please let me know if this is a Lennar Home RUCKUS setup?
Please confirm.
Thank you again.
09-17-2025 12:43 PM - edited 09-17-2025 12:46 PM
Yes it’s exactly Lennar Home Setup! Home was built in 2020. Here’s a photo of annother angle of where the AP was installed in the ceiling.
09-17-2025 12:53 PM
Hi @Auggie
09-17-2025 01:25 PM - edited 09-17-2025 01:26 PM
Ah! So the issue was the Ethernet cable connecting the AP to the Switch itself, noticed the clip was broken and so the connnection was loose. I tightened it and now power is back on the AP. Thank you!
There was no reason for me to unmount the AP since the issue was on the Switch side lol.
