08-04-2023 04:23 PM
My device is powering up anymore and has not lights on either. I have tried multiple power cables and power cycled the device and router as well. Online forums suggest to reset it with a pin have not worked either.
08-04-2023 04:57 PM
Hi @Pinderhayer
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS ICX-7150-C12P Switch is not powering up.
As you mentioned that you tried reset, once again we will try to reset the Switch as described below:
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
08-06-2023 04:33 PM
Hi Imran - thank you for this recommendation. I tried over 20 times and am still having no luck with my Ruckus system getting back online. Even my access points seem to have lost power / connection.
any further help would be greatly appreciated.
08-07-2023 08:41 AM
Hi @Pinderhayer
Could you please plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES and VIDEO of it showing the light status, and cord connected to the Switch and a working power outlet? Please refer to the below pictures as an example.
02-10-2024 02:20 AM
Hello Imran, I know it has been a while since you sent this solution - right now I was about to take those pictures and upload them. As I plugged the Ruckus in it lit up, however despite being powered up and plugged into the ISP it is not providing a connection to any devices connected to it. Could you help me out with this?
