Ruckus ICX7150 C12P Dynamic PoE Power Unavailable
chadm
I have several C12Ps, all running 9.0.10j:
#show ver
UNIT 1: compiled on Jan 12 2024 at 09:59:12 labeled as SPR09010j
(33554432 bytes) from Primary SPR09010j.bin (UFI)
SW: Version 09.0.10jT213
Compressed Primary Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
Compiled on Tue Nov 29 07:43:26 2022
The admin guide indicates that dynamic PoE power is configurable:
https://docs.commscope.com/bundle/fastiron-09010-managementguide/page/GUID-CAA036D6-595D-4481-A140-2...
"If you want to configure Static PM to a specific port after enabling Dynamic PM on all ports, configure the required ports with priority 1. Unless the Power Supply Unit (PSU) is removed, Priority 1 ports will never lose power. The following is an example of configuring a specific port to Static PM after Dynamic PM has been configured."
device# configure terminal
device(config)#inline power allocation dynamic all
device(config)# interface ethernet 1/1/15
device(config-if-e1000-1/1/15)#inline power priority 1
However, the CLI does not recognize this command:
SSH@adjunct.madison911.net(config)#inline power allocation dynamic all
Invalid input ->allocation dynamic all
Type ? for a list
Node doesn't exist
SSH@blah.net(config)#
I need this feature in the switch, as I cannot add additional access points to my homes' switches.  Despite each AP using at most 11 watts at peak, the switch preallocates 30watts from the budget, limiting the deployment to 4 APs at most.  This is well known of course in the 8.x line of code, which is why I moved to 9.0.10j as the release notes and admin guide indicated (as above) that dynamic power was available.
16 REPLIES 16
Imran_ruckus
Hi @chadm
Could you please let me know if this is a RUCKUS Lennar Home RUCKUS setup?
Please confirm.
Thank you again.
chadm
Correct.  I have multiple Lennar Homes, each outfitted with the ICX 7150 C12P
Hi @chadm
Thank you for the response and the confirmation.
Could you please help us with the below command outputs to check further?
show version
show flash
show inline power
show interface brief
chadm
Not a problem.  See below.
show version
HW: Stackable ICX7150-C12-POE
Serial #:<redacted for security>
Software Package: ICX7150_L3_SOFT_PACKAGE
Current License: 2X10GR
8 MB boot flash memory
2 GB code flash memory
1 GB DRAM
STACKID 1 system uptime is 42 day(s) 20 hour(s) 36 minute(s) 22 second(s)
The system started at 14:47:27 GMT-06 Mon Mar 11 2024
show flash
Stack unit 1:
Compressed Pri Code size = 33554432, Version:09.0.10jT213 (SPR09010j.bin)
Compressed Sec Code size = 33554432, Version:09.0.10jT213 (SPR09010j.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
Compressed Sec Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
Code Flash Free Space = 857878528
show inline power
Power Capacity: Total is 124000 mWatts. Current Free is 8600 mWatts.
Power Allocations: Requests Honored 29 times
1/1/1 On On 8600 28850 2P-IEEE Class 4 3 n/a
1/1/2 On On 9800 28850 2P-IEEE Class 4 3 n/a
1/1/3 On On 8000 28850 2P-IEEE Class 4 3 n/a
1/1/4 On On 8800 28850 2P-IEEE Class 4 3 n/a
1/1/5 On Off 0 0 n/a n/a 3 n/a
1/1/6 On Off 0 0 n/a n/a 3 n/a
1/1/7 On Off 0 0 n/a n/a 3 n/a
1/1/8 On Off 0 0 n/a n/a 3 n/a
1/1/9 On Off 0 0 n/a n/a 3 n/a
1/1/10 On Off 0 0 n/a n/a 3 n/a
1/1/11 On Off 0 0 n/a n/a 3 n/a
1/1/12 On Off 0 0 n/a n/a 3 n/a
Total 35200 115400
show int br
Port Link State Dupl Speed Trunk Tag Pvid Pri MAC Name
1/1/1 Up Forward Full 1G None Yes 10 0 <redacted for security>
1/1/2 Up Forward Full 1G None Yes 10 0 <redacted for security>
1/1/3 Up Forward Full 1G None Yes 10 0 <redacted for security>
1/1/4 Up Forward Full 1G None Yes 10 0 <redacted for security>
1/1/5 Down None None None None No 10 0 <redacted for security>
1/1/6 Down None None None None No 10 0 <redacted for security>
1/1/7 Down None None None None No 10 0 <redacted for security>
1/1/8 Down None None None None No 10 0 <redacted for security>
1/1/9 Down None None None None No 10 0 <redacted for security>
1/1/10 Down None None None None No 10 0 <redacted for security>
1/1/11 Down None None None None No 10 0 <redacted for security>
1/1/12 Down None None None None No 10 0 <redacted for security>
1/2/1 Down None None None None No 10 0 <redacted for security>
1/2/2 Down None None None None No 10 0 <redacted for security>
1/3/1 Down None None None None Yes 1 0 <redacted for security>
1/3/2 Up Forward Full 1G None Yes 1 0 <redacted for security>
mgmt1 Down None None None None No None 0 <redacted for security>
ve10 Up N/A N/A N/A None N/A N/A N/A <redacted for security>
