07-17-2023 01:46 PM
We tried all the suggestions including : https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-Switch-ICX-...
and tried upgrading firmware.
The steps were completed successfully (though I could see lots of crash messages on the console), still, the device only has 2 lights as shown in picture and wifi extender does not power on.
07-17-2023 01:54 PM
Hi @sebastso
Greetings of the day,
Based on the images you have shared it seems that your switch has one green and one yellow light, it means that the switch is stuck in boot mode.
07-20-2023 12:22 PM
We tried factory resetting multiple times, still, the device is stuck at boot, please see the logs below:
https://drive.google.com/drive/folders/1SsmjG1h8Svjt-Sf63kG57J05bKUYjTHP?usp=drive_link
07-20-2023 01:13 PM
Hi @sebastso
Thanks for your response.
If the resetting process doesn't work, we need to perform a software recovery.
07-21-2023 04:05 PM
Hi ,
We tried software recovery using TFTP and USB, still unable to resolve the issue as the file copy using TFTP keeps failing and when trying with USB, the copy commands do not work, we often get errors and crashes and unable to do anything. see attached vide/images.
https://drive.google.com/drive/folders/1J4tMmsHyf7D8D8kQC2L716hqoJqnv9Xe?usp=drive_link
We spent more than 6 hours following the steps mentioned in the link and yielded no result, let me know the next steps.
