07-10-2023 05:24 AM
Ruckus ICX 7150-C12P switch stopped working. SYST light amber, PWR light green. Consoled in to switch and tried to reset. Getting: "ERROR: can't get kernel image!"
ICX7150-Boot>reset
resetting ...
Next boot is from primary
verify_uboot_uimage: Cmd sf probe 0:0
Access set to PRIMARY FL..
SF: Detected MX25L6405D with page size device 0 offset 0x0, size 0xc0000
SF: 786432 bytes @ 0x0 Read: OK
using GPIO[7] to reset
Ruckus Wireless Bootloader: 10.1.15T225 (Jan 30 2019 - 23:08:47 -0800)
Booted from partition 1
DRAM: Validate Shmoo parameters stored in flash ..... OK
Logging is Enabled...
UBOOT: BE Mode
ICX7150-12 (POE), PVT1
SYS CPLD VER: 0x4 Released Ver: 0xa
Writing Shmoo values into flash .....
SF: Detected MX25L6405D with page size Unlocking L2 Cache ...Done
Net: Registering BCM xgs eth
Broadcom XGS Iproc Ethernet driver 0.1
Using GMAC0
gmac_mac_init: Chip ID: 0xb160
r = 0x0, addr = 0x1, devad = 0xffffffff, phy_id = 0x600d84aa
Add phy reset delay
Add phy reset delay
Basic ethernet functionality initialized
bcm_xgs_gmac-0 [PRIME] ETH MAC: 34:20:e3:31:bb:25
SF: Detected MX25L6405D with page size Flash set to SECONDARY FL
SF: Detected MX25L6405D with page size Erasing SPI flash...Writing to SPI flash...Access set to PRIMARY FL..
SF: Detected MX25L6405D with page size done
Valid environment: 2
SF: Detected MX25L6405D with page size device 0 offset 0xbfe00, size 0x200
SF: 512 bytes @ 0xbfe00 Read: OK
SF: Detected MX25L6405D with page size Access set to PRIMARY FL..
SF: Detected MX25L6405D with page size Erasing SPI flash...Writing to SPI flash...Flash set to SECONDARY FL
Valid environment: 1
Booted From: Uboot partition 1
bootdelay: ===
Booting image from Primary
NAND read: device 0 offset 0x0, size 0x2000000
7 ecc_errors after reading 1b48000:1b49800
iproc_nand_read_page returned 2
NAND read from offset 0 failed -22
0 bytes read: ERROR
## Loading kernel from FIT Image at 70000200 ...
Bad FIT kernel image format!
could not boot from primary, no valid image; trying to boot from secondary
BOOTING image from Secondary
NAND read: device 0 offset 0x4000000, size 0x2000000
1 ecc_errors after reading 5b48000:5b49000
NAND read from offset 4000000 failed -22
0 bytes read: ERROR
ICX7150-Boot>ERROR: can't get kernel image!
07-10-2023 08:06 AM
Followed steps - switch not booting. All amber lights still flashing.
Here's the putty results:
UBOOT: BE Mode
Using GMAC0
Add phy reset delay
Add phy reset delay
bootdelay: ===
Booting image from Secondary
4 ecc_errors after reading 5b48000:5b49c00
0 bytes read: ERROR
could not boot from secondary, no valid image; trying to boot from primary
BOOTING image from Primary
8 ecc_errors after reading 1b48000:1b49c00
0 bytes read: ERROR
ICX7150-Boot>
07-10-2023 08:27 AM
Hi @bbatjargal11
Please let us know whether you have tried software recovery process or not.
If not please perform the software recovery process using the below guide.
Also please share the output of the following commands.
Enable
Show version
Show flash
07-10-2023 09:50 AM
Here are the outputs of the following command. System recovery is not working either.
EnableICX7150-Boot>enable
Unknown command 'enable' - try 'help'
ICX7150-Boot>help
? - alias for 'help'
boot - boot default, i.e., run 'bootcmd'
boot_primary- boot from primary partition
boot_secondary- boot from secondary partition
bootm - boot application image from memory
cp - memory copy
cpld_read- Read from cpld
cpld_write- write to cpld
dump_cpld- Dump CPLD Registers
eeprom - EEPROM sub-system
ext2load- load binary file from a Ext2 filesystem
ext2ls - list files in a directory (default /)
help - print command description/usage
hwinfo - Show HW Info
i2c - I2C sub-system
logging_disable- Disable Uboot Logs.
logging_enable- Enable Uboot Logs.
md - memory display
nand - NAND sub-system
ping - send ICMP ECHO_REQUEST to network host
powercycle- Do a Hard Reset
printenv- print environment variables
reset - Perform RESET of the CPU
saveenv - save environment variables to persistent storage
setenv - set environment variables
sf - SPI flash sub-system
show_image- Show Stored Images.
tftpboot- boot image via network using TFTP protocol
update_primary- update primary partition
update_secondary- update secondary partition
update_uboot- - get the uboot image over tftp.
usb - USB sub-system
verify - Verify Image
version - print monitor, compiler and linker version
ICX7150-Boot>logging_enable
ICX7150-Boot>
Show version
ICX7150-Boot>version
armeb-buildroot-linux-gnueabi-gcc.br_real (Buildroot 2015.11.1) 4.9.3
GNU ld (GNU Binutils) 2.24
ICX7150-Boot>
Show flash
ICX7150-Boot>sf
Usage:
sf probe [[bus:]cs] [hz] [mode] - init flash device on given SPI bus
and chip select
sf read addr offset|partition len - read `len' bytes starting at
`offset' or from start of mtd
`partition'to memory at `addr'
sf write addr offset|partition len - write `len' bytes from memory
at `addr' to flash at `offset'
or to start of mtd `partition'
sf erase offset|partition [+]len - erase `len' bytes from `offset'
or from start of mtd `partition'
`+len' round up `len' to block size
sf update addr offset|partition len - erase and write `len' bytes from memory
sf protect lock/unlock sector len - protect/unprotect 'len' bytes starting
at address 'sector'
ICX7150-Boot>show_image
Primary :
512 bytes read: OK
SPS08090d(28660224)
Secondary:
512 bytes read: OK
SPS08090d(28660224)
ICX7150-Boot>
