Ruckus ICX 7150-C12P not working after power outage
Castlcvc
After the power outage. My ruckus switch only has two lights on. The "SYST" is in amber and the "PWR" is in green. I have unplugged and plugged back the switch but I am having the same issue. I have tried several times to use the reset button and plug the switch back in, but I just have all the light flash in amber for an eternity. I do not have a computer to perform a data reboot.
8 REPLIES 8
Created the follow case number and was closed immediately after I was flagged as a Lennar home. Ruckus Networks Support case 01517469.
I have tried using my MacBook and nothing getting anywhere. I have also tried multiple type c usb to regular usb cables to connect to the switch and no luck. I don’t know if my type c connection port is working.
Hi @Castlcvc
Based on your description, your switch has one green and one amber light which means that the switch is stuck in boot mode.
Please try to do the factory reset process again as mentioned below.
  1.  Remove power from the switch.
If the resetting process doesn't work, we need to perform a software recovery.
While performing software recovery please confirm whether the cables are connected properly by using the below link.
How to console in the ICX-7150-12CP 'Ruckus Switch'
Castlcvc
Hi @Castlcvc
Greetings of the day!!!
Hope you are doing good.
Could you please update on the status of this issue?
