05-25-2023 05:40 PM
Already tried different power cords/outlets, but no luck. Also tried the reset instructions below, no work either. Please help.
05-29-2023 09:59 AM
Hi @vfxer
Greetings of the day!!!
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged into a power outlet there is no power to the Switch. Also, you tried to reset the Switch. And you confirm that the Switch is plugged into a well-known outlet/power source also tried with different cords. However, the failure persists. This unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
