06-16-2023 08:03 PM
RUCKUS ICX 7150-C12P stopped working and all status LEDs are on and solid amber. I have tried the factory reset more than 10 times and the status lights never change from solid amber when applying power. I have also tried the software reload with no avail.
06-16-2023 10:46 PM - edited 06-16-2023 10:49 PM
Hi ,
Greetings !
It seems like switch is stuck in boot mode.
Basically, due the power outage / spike of power / the switch went to a state that we called (boot-mode) that is not able to boot up properly.
1-Please try to disconnect from the Power outlet the ICX-7150 and reconnected.
Remove power from the switch.
Press and hold the Reset button while applying power to the switch.
After all the system LEDs flash amber, release the Reset button.
If that does not make any difference, we need to perform a software recovery since it can be that the image flash is corrupted so in basic words the unit is not able to boot up properly and need re-install the image to boot up properly.
3-We need to access (physical) using one of the cables to the ICX-7150C12P mentioned on the below guide:
How to console in the ICX-7150-12cp
Once we are there, we can try to boot up the unit using the following commands:
Boot_primary or Boot_secondary
If that step does not work Software recovery needs to be applied
Here is the guide:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-r...
If the above steps dosent resolve issue ,See if you can use the below link to create a case with us.
https://support.ruckuswireless.com/case_management
Note: Please feel free to mark the post as ACCEPTED SOLUTIONS if its addressed your query.
Regards ,
Deepu Sekar
06-17-2023 11:19 AM
I have done this, I have downloaded the drivers and attempted to connect to the device via console, it does not work. Can we please RMA this switch?
06-18-2023 09:42 AM
Any update so that I can get this switch RMA’d?
06-19-2023 09:14 AM
Hi @mj2023
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS ICX-7150-C12P Switch is stuck in boot mode.
Apologies, as this is a software issue, we cannot replace the Switch if it is a software issue. Warranty is not covered on software issues as it can be fixed by the troubleshooting steps.
As you have tried resetting it multiple times with a paper clip,
Please do let us know if there is any help required on the troubleshooting steps or if you are stuck at any point.
