10-14-2023 01:38 PM
There are no status lights on the unit. I unplugged the power cable and plugged back in. The amber lights flash for a quick second and then no lights at all. I can’t console into the device. I tried changing out the power cable from a working computer, and I've tested the power outlet. I tried to reset the device by unplugging the power cable, pressing the reset button with a paper clip and plugging back in. The amber lights flash quickly and then no lights at all. Please advise.
10-16-2023 11:05 AM
Hi @darren_dickerso
Thank you for the response and for sharing the requested information.
This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Thank you again and we appreciate your patience.
Kind regards,
Sofia Gätjens
10-14-2023 01:39 PM
Also there have been no power outages recently.
10-16-2023 08:59 AM
Hi @darren_dickerso
As per the case description, I understand that your RUCKUS setup is not working, with the RUCKUS ICX-7150-C12P Switch disconnected on the Unleashed system.
2. Please refer to the below picture and share a picture of the same, showing the FULL Switch panel cable connections to the Switch ports.
Please let me know the answers to ALL the above queries or let me know if you have any queries in this regard.
Kind regards
Sofia Gätjens
10-16-2023 09:35 AM
Yes it was working fine before and we've had no power outages. Please see the attached picture and let me know if you need anything else.
10-16-2023 11:05 AM
Hi @darren_dickerso
Kind regards,
Sofia Gätjens
