12-20-2025 11:57 AM
12-22-2025 05:44 AM
Hi @Fshinwari
From the case description, I understand that the status lights on the Switch is Amber and the PWR light is Green which means that the Switch is stuck in the boot mode.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is in boot mode.
Also, I understand that you have followed the steps online and still stuck in boot mode.
May I please know if you have performed reset on Switch multiple times and if the reset still doesn’t work, could you please mention the point where you are getting stuck during Software recovery?
If you could share screenshot, we could look into the matter and assist you accordingly.
12-24-2025 05:56 AM
Hello @Fshinwari ,
12-31-2025 05:10 AM
Hello @Fshinwari ,
01-02-2026 05:26 AM
Hi @Fshinwari ,
Thank you.
