Ruckus APs dropping WiFi Connection
pushpa_hegde
My ruckus wifi keeps dropping connections randomly. Sometimes it lasts hours and sometimes a few minutes. As with the other posts, it started randomly last week or so. The outside internet is good as my computer switches to the wireless router that feeds the switch has good internet.
What I have seen is when we lost the internet, the green stat light on the switch disappears and instead an amber light flashes. Then it goes through the power cycle, turns on to a solid green stat light and all the APs reboot themselves. A 5-10 minute process all together.
I have had no changes to the setup in the last 3 years we have owned the home.
Was a firmware pushed out to the switch that is causing the spate of issues?
15 REPLIES 15
No such luck 😞
The switches rebooted again. Same as before. What do we do now?
Valued Contributor III
Hi @pushpa_hegde
For detailed understanding of the issue please let us know how many access points are connected to the switch.
Please let us know whether you have upgraded the APs to the newer version or not.
If yes, please check whether the Access points are upgraded to same firmware version or not.
Once you have confirmed it please check whether the Access points are rebooting randomly even after the Access points are upgraded to same version.
You asked me to downgrade the firmware to a lower version which I did yesterday. I am on 200.9. All APs are on the same version.
I was on 200.14 before and you asked me to downgrade.
We are going around in circles here.
Hi @pushpa_hegde
For detailed understanding of the issue please follow the below steps and share the output of the below commands.
1- To fix this issue, we must identify the ‘currently’ IP address assigned by your local router to the switch
-We can try the IP address that shows in the dashboard copy and paste it in the URL if that redirects you to the login page for the ICX-7150-C12P that is the correct one if not.
I will leave you a guide how to perform an IP scanner on your local network to identify the switch IP address very easily.
2-Once we identified the IP address of the switch proceed to access remote to the device 'command Line'
If you can access to the Command line should look like this:
ICX7150-C12 Router> or
ICX7150-C12 Switch>
  1. Now please perform the following commands and share the output:
Show flash
Show version
Show inline power
Show inline power detail
Here you go -
