06-02-2025 07:16 AM
Lennar home, first owner. Been using the Ruckus with our home since 2019. After a power outage 2 weeks ago our ruckus network hasn't been performing. Our LAN and wired connections work fine but WiFi is showing connections but nothing loads or it's greatly reduced. We've rebooted the Ruckus many times and rebooted the WAPs but it's not working for WiFi. Not sure what to do or if this is a hardware problem. I’ve also flashed the APs and updated the firmware to 200.15 and the issue still persists. Hardline connections are working throughout the home, WiFi shows connection and either is very slow by normal conditions, doesn’t load others, or works normally for others. The majority of the time it shows connection for WiFi but nothing loads despite having full signal connection.
06-17-2025 04:29 AM
I will try to get those tonight.
Is it possible to get a technician out here to fix this? I'm not an IT person.
06-17-2025 05:25 AM
Hi @mbotkin
Apologies for the inconvenience caused. Please note that this community forum operates on a best-effort basis and does not offer dedicated technician support.
That said, I’m here to assist you, and we’ll work together to resolve the issue as quickly as possible.
Kindly keep me posted once you’ve had a chance to try the suggested steps.
06-19-2025 05:27 AM
Hi @mbotkin
Thank you.
06-19-2025 12:15 PM
Haven't had a chance to continue working on this. I work fulltime so my ability to try different solutions has small windows.
06-19-2025 12:36 PM
Hi @mbotkin
Kindly let me know once you've had a chance to try, so we can determine the next steps accordingly.
