Showing results forย
Search instead forย
Did you mean:ย
Reset did not work
ruckus_houston
We had a power outage in our home and APs lost power.
To resolve this problem, I searched through this forum and found posts that recommended resetting the switch [ ICX7150-C12P].
So I reset the switch using a pin pressing against the Reset button while applying power to the switch.
Now all light on the switch are flashing, and still no power to AP.
Please advise.
14 REPLIES 14
pinky_ruckus
Valued Contributor III
Hi @ruckus_houston
As per the case description, I understand that your RUCKUS APs are not turning on after the power outage.
1)   On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
2)   May I know how many Access Points are connected to the Switch?
pinky_ruckus
Hello @ruckus_houston ,
1. I am attaching a pictures here, due to the small area where this switch is installed its not possible to provide all details in one picture.
2. 5 APs are connected to this switch, details in picture.
Hi @ruckus_houston
From the Pictures you shared, I could see that your RUCKUS ICX-7150-C12P Switch has an Amber/Yellow SYST LED that means the Switch is stuck in boot mode.
Please refer to the below RUCKUS Lennar Knowledge Base self-help article to troubleshoot and fix this issue.
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/Fixing-RUCKUS-Switch-with-an...
Please do not hesitate to reach out if you are stuck at any point during the process.
