02-09-2026 07:05 PM
I received my replacement device and hooked it back up with the wires, ethernet cable, etc. Now I need help on how to connect it to my network. All of the instructions I see indicate to connect the ethernet cable to the AP device but I am unable to do that. Please help!
02-10-2026 05:26 AM
Hello @Bsierra
From the case description, I understand that you have received a replacement Ruckus Switch and is trying to set the network.
For guidance on setting up your system, please refer to the RUCKUS Lennar Knowledge Base self-help article linked below. The article includes detailed instructions for the setup process.
Should you require further assistance or have any questions, please do not hesitate to reach out.
02-11-2026 06:35 AM
02-11-2026 07:19 AM
Hello @Bsierra ,
Thank you for your response.
From the response shared, I understand that you have connected all the devices according to the provided guidelines.
In Step 6, you are required to connect to the Ruckus access point’s Wi-Fi network through your device’s Wi-Fi settings.
Please search for the available networks and select the access point’s Wi-Fi name (SSID), then enter the password printed on the device.
If you have any questions or need further assistance, please let us know.
02-11-2026 07:28 AM
