Re: RUCKUS Ethernet Connection Issues
Clark
This is a great response and this might be a basic question, but I'm hoping you can provide more detail on how to check whether the Ruckus AP is in Bridge mode or Router mode? I have looked all over the Ruckus Unleased interface and I don't know how to check whether my APs are in bridge mode. I seem to have the same problem last the original poster.
6 REPLIES 6
Imran_ruckus
Hi @Clark
Based on the information provided, it appears that you are encountering issues with the RUCKUS Setup.
1. Could you please confirm if this is a Lennar Home RUCKUS setup? If yes, please help with answers to the below queries.
2. Can you confirm if your RUCKUS setup was previously operational, and if there were any power outages before the issue began?
3. When your switch is connected to the outlet, do you observe any illuminated lights (amber or green)? Kindly describe which lights are visible. Additionally, please provide a photo showing the status of the lights and the full switch panel with cable connections to the switch ports.
4. Is your internet connection from the ISP stable and functioning? You can verify this by connecting to your local router's Wi-Fi or through an ethernet cable from the router to a laptop/PC.
5. How many access points are currently connected to the switch? Please describe the status of the lights on the access points. Similarly, include a photo showing the access points' light status.
Please help us with ALL the above queries and should you have any further questions or concerns, feel free to reach out.
Imran_ruckus
Hi @Clark
Thank you.
Imran_ruckus
Hi @Clark
Thank you.
Imran_ruckus
Hi @Clark
Thank you.
