12-07-2024 05:02 PM
Hi Imran,
I followed the steps to reset entire unleashed network using the SSH option as detailed in method#3 given in this link:
and it worked. After doing factor reset of the master AP, now I am able to configure my master AP to connect my wireless network and the member AP also join the master AP as mentioned in above link.
The only issue i now have is i am unable to login into the unleashed mobile app on my phone using the same admin user name and password that i had set up on unleashed.ruckuswireless.com login page.
Any pointers for logging into the unleashed mobile app will be helpful.
Thanks,
Pravin.
12-21-2024 12:49 AM
Hi Imran,
My apologies for the delay from my end to try out the firmware upgrade option earlier this week. So I followed your instructions mentioned above and did the firmware upgrade using the Online upgrade option and thereafter i removed the Ruckus unleashed app on my smartphone and reinstalled the updated version of the app. Even after the firmware upgrade, I didn't have to reconfigure neither of both my AP's nor set up a new SSID, as it was able to retain my wireless configuration done earlier, so was able to connect back to my same SSID that I had set up earlier.
Thereafter, I was able to login into the app successfully and I can view my wireless network info in the Ruckus unleashed app with all the network details, AP details etc.
Thanks so much for resolving this issue.
Thanks,
Pravin.
12-16-2024 05:30 AM
Hi @pravinsv
Thank you.
12-18-2024 04:02 AM
Hi @pravinsv
Thank you.
12-20-2024 04:11 AM
Hi @pravinsv
Thank you.
12-21-2024 12:49 AM
Hi Imran,
Thanks,
Pravin.
12-23-2024 04:41 AM
Hi @pravinsv
Great!!! Good to know that the issue is now resolved.
Have a great day ahead!!!
