Re: Need help in setting up Ruckus switch and Ruckus AP to connect to my xfinity wifi network
pravinsv
Hi Imran,
I followed the steps to reset entire unleashed network using the SSH option as detailed in method#3 given in this link:
https://community.ruckuswireless.com/t5/RUCKUS-Self-Help/How-to-reset-entire-Unleashed-network-for-r...
and it worked. After doing factor reset of the master AP, now I am able to configure my master AP to connect my wireless network and the member AP also join the master AP as mentioned in above link.
The only issue i now have is i am unable to login into the unleashed mobile app on my phone using the same admin user name and password that i had set up on unleashed.ruckuswireless.com login page.
Any pointers for logging into the unleashed mobile app will be helpful.
Thanks,
Pravin.
1 ACCEPTED SOLUTION
Hi Imran,
My apologies for the delay from my end to try out the firmware upgrade option earlier this week. So I followed your instructions mentioned above and did the firmware upgrade using the Online upgrade option and thereafter i removed the Ruckus unleashed app on my smartphone and reinstalled the updated version of the app. Even after the firmware upgrade, I didn't have to reconfigure neither of both my AP's nor set up a new SSID, as it was able to retain my wireless configuration done earlier, so was able to connect back to my same SSID that I had set up earlier.
Thereafter, I was able to login into the app successfully and I can view my wireless network info in the Ruckus unleashed app with all the network details, AP details etc.
Thanks so much for resolving this issue.
Thanks,
Pravin.
14 REPLIES 14
Hi @pravinsv
Thank you.
Hi @pravinsv
Thank you.
Hi @pravinsv
Thank you.
Hi Imran,
Thanks,
Pravin.
Hi  @pravinsv
Great!!! Good to know that the issue is now resolved.
Have a great day ahead!!!
