Re: ICX7150-C12P-2X1G not Powering up. Cables burnt inside
Gaurav
I am having exact same issue. The switch is not powering up and none of the lights are on.. Nothing happens when I press the status button or try to reset it.
1 ACCEPTED SOLUTION
Imran_ruckus
Hi @Gaurav
Greetings,
This case has been brought to our attention by @Shoats
To ensure clarity in our communication, we kindly request that you create a separate post query on this RUCKUS Lennar Support outlining the issue you are experiencing. Please provide a detailed description of the network problem you are encountering, as well as any troubleshooting steps you have already undertaken. This will enable us to offer you tailored guidance and support.
Thank you once again for your cooperation and understanding.
2 REPLIES 2
Imran_ruckus
Admin test
Imran_ruckus
Hi @Gaurav
Greetings,
