R510 is defective after power cycle
thejammer
Ive tried restoring the bak file and it wont do anything. The AP is connected to a router and it is unable to get an internet connection. Unit seems defective and shows up as lifetime warranty on the site.
21 REPLIES 21
Imran_ruckus
Hi @thejammer
As per the case description, I understand that one of your RUCKUS Access Points is not working.
1. Was this working before or is it a new installation? If it worked before, was there any power outage before you started facing this issue?
2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
4. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
Please let me know the answers to ALL the above queries or let me know if you have any queries in this regard.
1. Yes it worked but recently it started having odd issues. No there was power outage, i simply did a reboot because of performance issues.
2. Power is flashing, ctl/2.4g and 5g are all solid green.
3. Internet is working fine when connecting directly to modem
4. Single access point
It wont let me upload a pic even when logged in
Hi @thejammer
It should allow to upload the Pictures when logged in. If still its not allowing you upload the pictures, please use the below link to upload them.
https://drive.google.com/drive/folders/1vJZC6HkGGb8O4pg-rXI46Bz4S2VCL4PC
