R510 AP POE injector LED light (left light) is blinking amber. What does it mean?
Itiskashi
The inline power stats look fine. There is no event or warning message on the unleashed dashboard.
What is causing this POE injector LED light to show up as amber? My other two access points show the rightside POE injector LED light as green color.
WhatsApp Image 2023-04-20 at 5.31.37 PM.jpegWhatsApp Image 2023-04-20 at 5.31.37 PM (1).jpeg
1 REPLY 1
Imran_ruckus
Community Manager
Community Manager
Hi @Itiskashi
Hope you are doing well!!!
The PoE port light of the RUCKUS R510 Access Point just means the PoE is working. However, please try to use a different ethernet cable and check the AP if the green light on the port. And all other AP lights on the front panel also are in the normal state. Please refer to the below link for the same.
https://docs.commscope.com/bundle/unleashed-200.9-onlinehelp/page/GUID-19D4261B-D10B-4DE3-B63A-3498F...
Could you let us know if there are any network issues you are facing with the RUCKUS setup? If yes, please elaborate in detail to assist you accordingly.
Thank you again.
Lennar Home Community.
