04-21-2023 08:46 AM
Just establish an account. Email address [email protected]. Sorry for the duplicate issue. Bought a new construction townhome with Lennar in May 2018 with the Ruckus wireless system pre-installed in my house. Recently, had inclement weather and both the upstairs and downstairs R510 access point units no longer have power. The ICX 7150-C12P seems okay but the ports that both R510s are plugged into do not respond.
Need help please,
Fred Tallent
Kissimmee, Fl.
04-21-2023 08:28 PM
BTW I have switched the port connections from the 11:54 am Reply
04-24-2023 04:46 AM
Just noticed that I did not indicate the color status for Port #11 on my previous reply. Port #11 - Lutron Lights -Amber.
04-24-2023 09:25 AM
Hi @FET4771
Thanks for the details provided.
Basically if the switch has one green and one yellow light, it means that the switch is stuck in boot mode.
If this step doesn't work, we need to perform a software recovery.
If the resetting process doesn't work, we need to perform a software recovery.
04-24-2023 12:22 PM
Hi @FET4771
Sorry for the inconvenience.
2-Please try to press the reset button using a paper click or a small stick .
Please follow the below link which explains the hard reset of the switch in detail.
05-02-2023 07:27 AM
Hi @FET4771
If the factory reset process doesn't work, we can try performing software recovery process.
