01-22-2025 01:44 PM - edited 01-22-2025 01:45 PM
I was able to get my R510 Access Point to work only by connecting to the 12 vdc as the PoE does not seem to work. I have the IP for my 7150 switch, but I can't seem to login. I tried the default user name and password already. So I tried to factory reset the switch following the protocol of unplugging the switch, pressing the reset button for 15 seconds, plugging the switch back in while still holding the reset button for 30 seconds, but the lights don't seem to flicker to indicate that the reset has begun. I was reading that I need to enter the command lines to enable the PoE, but i don't think i can do that unless i can access the switch via the IP. Please help.
02-03-2025 06:46 PM - edited 02-03-2025 06:48 PM
So i got the PoE to work and the AP have green lights. How do I access the internet through the access points?
02-06-2025 06:23 AM
Hello @anjo2290 ,
From the response you shared, I understand that the PoE is enabled now and the APs are turning red.
Could you please unplug the Access point cable from the port which is connected to the Switch (please refer to the below figure) and connect it back to any other 12 ports in the Switch and kindly check if the AP is turning on?
02-10-2025 06:56 AM
Hello @anjo2290 ,
02-14-2025 07:05 AM
Hello @anjo2290 ,
02-17-2025 07:19 AM
Hi @anjo2290 ,
Thank you.
