PoE not functioning after recent Power Outage - ICX7150-CP12 Switch - Cannot factory reset
SG11
I am looking for some advice and assistance with my Ruckus ICX-7150-CP12 switch.  After a recent power outage, the PoE function did not come back online when router and switch rebooted. Both the power and system lights are solid green, but no ports are providing PoE.  I have read dozens of different posts on this forum and none seem to completely diagnose my scenario.  I downloaded Putty and connected to the switch; I pulled the following information based on some instructions I saw in other posts:
ICX7150-C12 Switch#show version
Copyright (c) 1996-2017 Brocade Communications Systems, Inc. All rights reserved.
UNIT 1: compiled on Aug 14 2017 at 06:54:44 labeled as SPS08061a
(24723488 bytes) from Primary
SW: Version 08.0.61aT211
Compressed Boot-Monitor Image size = 786944, Version:10.1.10T225 (mnz10110)
Compiled on Sun Jun 25 09:25:15 2017
HW: Stackable ICX7150-C12-POE
Serial #:FEK3204P14B
Current License:
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 40 minute(s) 3 second(s)
The system started at 00:06:02 GMT+00 Sun Jan 02 2000
The system : started=warm start reloaded=by "reload"
ICX7150-C12 Switch#show inline power
Power Capacity: Total is 124000 mWatts. Current Free is 124000 mWatts.
Power Allocations: Requests Honored 0 times
1/1/1 Off Off 0 0 n/a n/a 3 n/a
1/1/2 Off Off 0 0 n/a n/a 3 n/a
1/1/3 Off Off 0 0 n/a n/a 3 n/a
1/1/4 Off Off 0 0 n/a n/a 3 n/a
1/1/5 Off Off 0 0 n/a n/a 3 n/a
1/1/6 Off Off 0 0 n/a n/a 3 n/a
1/1/7 Off Off 0 0 n/a n/a 3 n/a
1/1/8 Off Off 0 0 n/a n/a 3 n/a
1/1/9 Off Off 0 0 n/a n/a 3 n/a
1/1/10 Off Off 0 0 n/a n/a 3 n/a
1/1/11 Off Off 0 0 n/a n/a 3 n/a
1/1/12 Off Off 0 0 n/a n/a 3 n/a
Total 0 0
ICX7150-C12 Switch#show inline power detail
Power Supply Data On unit 1:
Power Supply Data:
Power Supply #1:
Max Curr: 2.3 Amps
Voltage: 54.0 Volts
Capacity: 124 Watts
PoePower: 124 Watts
POE Details Info. On Unit 1 :
General PoE Data:
I have power cycled, disconnected cables, reconnected cables and nothing has restored PoE function.  One of my neighbors experienced a similar problem after the power outage.  He was able to restore PoE by doing a manual factory reset.  I have since tried doing that following the instructions on this forum, and my switch will seemingly not reset.  I disconnect the plug from outlet, wait a moment, insert paperclip into reset port until I feel the button click, depress the button while plugging the cord into power, continue holding button while waiting for amber lights to flash... but no amber lights flash after 20-30 seconds.  I have tried that 3 times. Am I doing it wrong?  Any thoughts or ideas on how I proceed from here would be greatly appreciated.
1 ACCEPTED SOLUTION
Yarenis
Hi @SG11
Thanks for the details provided, I can see the PoE is disabled, so will be matter to enable it back, now I will advise when you have time upgrade the switch to the code 08095g, let me add the steps to enable back PoE and save the changes.
Enabling PoE:
Lennar#configure terminal
Lennar(config)#interface ethernet 1/1/1 to 1/1/12
Lennar(config-mif-1/1/1-1/1/12)#inline power
Lennar(config-mif-1/1/1-1/1/12)#write memory
Lennar(config-mif-1/1/1-1/1/12)#show inline power
Here you can see that the admin state is on, because I have enabled it back.
Here are two options to perform the upgrade to the recommended code 08095, take in consideration that like you are in an old code, the upgrade must be done twice from where you are 08061 to 08080f then from 08080f to 08095 UFI, and you will always use the image that start with SPS
Yarenis Hernández
8 REPLIES 8
SG11
I had no cords connected to ports when attempting to re-enable PoE.  Should I have had them connected at that time?  If so, I will reattempt. If not, I will proceed to trying to upgrade the code.
Hi @SG11
Please perform the upgrade, will be the best.
Yarenis Hernández
SG11
Thank you very much.  I have now upgraded both primary and secondary partitions to 08095h code.  My network has been restored. I greatly appreciate your assistance. 😁
Hi @SG11
I'm glad, you are now a master😎
Yarenis Hernández
