03-17-2026 11:49 AM
Our R510 AP works great indoors. However, the signal only extends about 8 feet outside of our hurricane glass sliding doors. The total distance from the R510 to the sliding glass doors is only 22 feet, so this gives a range of only 30 feet. Is there a signal booster that could be plugged in outside or is another wired AP required? If so, what signal booster or AP is recommended? There is a covered area outside, so it is protected from the elements with ambient temperatures ranging from 40-95 degrees F.
03-17-2026 12:05 PM
Hi @MizzouWoman
Based on the information provided, it appears that you are looking extend your Wi-Fi connectivity range.
The RUCKUS R510 Access Point is specifically designed for indoor Wi-Fi deployments and optimized for indoor coverage and performance.
What you're experiencing is actually expected behavior for an indoor AP like the R510.
The R510 is designed for indoor use, and materials like hurricane/impact glass can significantly attenuate Wi-Fi signals. Even standard glass can reduce signal strength, and coated or reinforced glass can block it even more, which is why you're only seeing ~8 ft of usable signal outside.
In this scenario, there are two important points:
1. Wi-Fi “boosters” are not recommended
2. Best practice = add another AP (recommended solution)
Recommended options:
If running Ethernet is difficult, you can also consider RUCKUS Mesh, but performance will be better with a wired AP.
If you are looking to extend Wi-Fi coverage to outdoor areas, RUCKUS offers a dedicated range of outdoor Access Points that are built to handle environmental factors such as weather, temperature variations, and longer-range coverage requirements.
You may try to contact the local authorized seller to know more about the Outdoor APs.
For more details, please contact the authorized RUCKUS Seller through the link below. The team will be happy to assist you with the necessary information.
https://www.ruckusnetworks.com/partners/partner-locator/
https://www.commscope.com/partners/partner-locator/
If you have any further questions, please feel free to reach out.
Thank you again for your patience!
03-18-2026 09:03 AM
Hi @MizzouWoman
Thank you for your patience.
RUCKUS Access Point power supply part numbers (typically formatted as 902-xxxx-xxxx) can be found on the label of the original power adapter, within the RUCKUS Accessory Guide, or by contacting an authorized reseller. One commonly used model is 902-1169-XX00 (12V).
Please refer to the detailed screenshot provided below for further clarity.
We hope this information is helpful.
Thank you again for your continued patience and understanding.
03-18-2026 09:33 AM
Thank you!
03-18-2026 09:33 AM
Thank you!
03-18-2026 09:45 AM
Hi @MizzouWoman
Thank you for your response.
We truly appreciate your time and patience throughout this case.
Thank you once again for reaching out to the RUCKUS Lennar Home Community. Should you have any further questions or need assistance in the future, please don’t hesitate to contact us.
Wishing you a wonderful day ahead!
04-02-2026 11:44 AM
Using the part list that you supplied, I have looked and looked for a AC/DC power supply with a 3 pin female connector that is needed for the E510. I have searched and ordered parts online, been to a local electrical supply store and Best Buy. There is no local Ruckus partner in my area. Would you send me a link to a place that will supply this part? Thanks in advance for your assistance.
04-03-2026 01:01 PM
Hi @MizzouWoman
Could you please try contacting RUCKUS Support using the link below:
They may be able to help you identify the exact compatible power accessory and resources for your device.
Please keep me updated on the outcome. If this approach does not resolve the issue, I will be happy to assist you with the next steps.
RUCKUS | Community Forums Support
04-07-2026 08:50 AM
I used the supplied support link and found the following:
I just need to order a power supply that will work with the E510. My model has a 3 pin power connector, so it requires a female connection. Any help that you can provide will be appreciated. Thanks.
