12-17-2023 09:15 AM
12-18-2023 04:57 AM
Hi @Eric52894
Greetings of the day,
To understand the root cause of the issue please provide the detailed description of the issue.
Please let us know the LED status of the switch and the access points using the below guide.
R510 LED lights
RUCKUS LED lights
Also please share the image of the switch and the access points showing the LED status and the cable connections.
12-24-2023 02:13 PM
How can I replace the ruckus extender?
12-25-2023 06:03 AM
Hi @Nrokosa
Hope you are doing well
As this case is raised by @Eric52894 which is now closed.
To avoid confusion with posts, you can create your own post with the problem you're facing and a detailed description of the network issue and what you've done so that we can guide you properly.
