02-09-2024 12:10 PM
I have no power to my downstairs access point. Also, I can access my unleashed account via web but not on the mobile app. Upon logging in I notice that my home network name is incorrect. Could you please assist?
03-20-2024 05:49 AM
Hi @ynv_naw
As I see SSH is not enabled on the Switch (Please refer to the below screenshot)
Please enable the SSH manually by performing the below commands and Switch will be added to the Unleashed system sometime after you perform the commands.
please run the following command:
device>enable
device#configure terminal
device(config)#crypto key generate
device(config)#write memory
May I know which light is Red on the Access Point? Please refer to the below link for more information about the light status of the RUCKUS R510 Access Point.
04-01-2024 08:00 AM
Hi @Imran_ruckus:
It seems the access point downstairs continues to randomly reboot as to why the red light is on. Do you know what could cause this behavior?
Also the switch does not show after the commands. I tried to add using the add option listed under switch to no avail. I continue to receive incorrect credentials and the switch only support ICX firmware version 08.0.90 or later, and I am on 08.0.95g according to the update that was recently completed. What could cause this issue?
04-01-2024 10:59 AM
Hi @ynv_naw
The 08.0.90 or later information will be a permanent notification even if your Switch is on the latest version.
We suggest factory resetting your RUCKUS Access Points and configuring them with a new Wi-Fi SSID/Network.
Please refer to the below RUCKUS Lennar Knowledge base self-help article for the factory reset process and follow the same.
04-05-2024 01:26 PM
Hi @ynv_naw
Hope you are doing well.
Could you please provide an update on the status of the issue to proceed further?
Thank you.
