No power to ICX 7150
ralforja
Hi.  Reading the other similar post I believe my ICX7150 is not powering up as well.  When plugged into a reliable power source the front lights of the switch will momentarily flash then disappear.  When the status button is pressed no lights will turn on.  I am trying to upload a video to here but it says I do not have permission.
1 ACCEPTED SOLUTION
Hi @ralforja
Greetings of the day!!!
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, it flashes an amber light and then goes dark and you tried hard reset. You confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
6 REPLIES 6
Imran_ruckus
Hi @ralforja
Did you try to hard reset the RUCKUS ICX-7150-C12P Switch using a paper clip? If not, please try following the mentioned RUCKUS Lennar Knowledge Base self-help article below:
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/Process-for-performing-a-phy...
If hard reset doesn't work, we kindly request that you follow the steps outlined below:
Hi Imran,
I believe I uploaded a video with 3 photos.  Please review.  I hope I did it correctly.
Thanks for your time
Ron
Sorry, I forgot to add that the hard reset with paperclip did not work.
Hi @ralforja
Type a product name
