08-12-2023 07:34 AM
-I’m in a Lennar home Canopy Grove Escondido, CA.
-cant access the switch since power outage.
-ICX 7150-C12P with 2 wireless access points.
-no power or lights on both access points.
restart of power didn’t change anything.
08-14-2023 10:30 AM
EVERY light on both AP’s are out. It’s blank. Nothing is lit up.
08-14-2023 10:42 AM
Hi @BlowBoatTech
Thanks for the response.
Based on your description your switch has one green and one yellow light, it means that the switch is stuck in boot mode.
08-14-2023 11:19 AM
Status lights have been flashing for 10 minutes after I released the reset button.
still no lights on AP’s
08-14-2023 11:58 AM
Hi @BlowBoatTech
If the resetting process doesn't work, we need to perform a software recovery.
08-30-2023 12:36 PM
Quick guide? First off your software only cover Mac OS from 2016! Who has a computer running an OS that old? I tried it and it was a waste of my time. I just finished downloading the programs for a PC but it seems my cable isn’t compatible. I tried using a USB to USB-C data transfer cable is already had. I’m guessing I have to go buy a dedicated USB to USB-C cable for this to communicate?
