No power on ruckus switch
peterdomingo23
I tried different power cord, I tried to plug in to another outlet still no power
2 ACCEPTED SOLUTIONS
peterdomingo23
I do IT work, I know if there a power on the device
12 REPLIES 12
peterdomingo23
Hi @peterdomingo23
We need to confirm with a picture as a part of our process.
Please share a picture of the front and back panels of the switch.  Also, please ensure the ICX7150-C12P is plugged into a known outlet/power source.
Before uploading the photos, please log in to the RUCKUS account and you can upload the image.
Thank you again for your patience and understanding
Lennar Home Community.
Hi @peterdomingo23
Please try to reset the Switch once as described below:
  • Remove power from the switch.
  • Press and hold the Reset button while applying power to the switch.
  • After all the system LEDs flash amber, release the Reset button.
If the reset doesn’t work, please plug your ICX-7150-C12P Switch into a power outlet and send us a picture of it showing the light status and power outlet. Please refer to the below picture as an example.
kvamshi
I have the same problem. What was the resolution?
